Two handle kitchen Faucet invisible screw: Leaking Faucet
Not sure of the brand, but have you checked to see if the caps over the ends of the levers (shortest end extending beyond the post) doesn't have a press on cap? They are very hard to detect sometimes and even more difficult to remove. It would expose the set screw that secures the handle to the post. From there you are ok. If you feel that this cap is the answer, dry it well and let a drop of liquid wrench or similar lube set a while, then attempt to carefully press a strong yet sharp blade, lifting from the bottom at the point where it meets the post, so as to not leave any noticable marks.
Looked closer at that handle, check both ends for the possibility of a press on cap.
If you don't have time to do it right, when will you ever have time to do it over?
Reason: add on
