Two Gas Water Heaters Hooked In Series - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2013, 04:22 PM   #1
two gas water heaters hooked in series
How do I safely drain them to clear of sediment. First time in eight years. Located in the attic of a modern expensive house???
col lane is offline   Reply With Quote
Old 01-19-2013, 06:52 PM   #2
Rewards Points: 1,506
You can drain the sediment from the heaters one at a time in the two normal fashions.
1. (starting with the first heater) Simply open the drain valve and let the water flow until it is clear.
2. (starting with the second heater) Turn off both heaters' heating (turn the knob to pilot). Turn off the cold water supply to the first heater. Open a hot faucet upstairs. Open the drain valve and let the water flow until it is clear. Turn on the water and have the hot faucet gushing before turning the heat back on.
In both cases no one should be using hot water for several hours before you start the procedure. If you choose to do both procedures at about the same time, wait several hours in between. But you can do both tanks in quick succession for one procedure. Typically draining the sediment every 6 months (one procedure, alternated) should be enough each time.
Old 01-19-2013, 08:54 PM   #3
Rewards Points: 13,472
I'd also suggest removing the aerators on the faucets and flush out the lines.
Sure hope those heaters are sitting in drain pans with a drain running to the outside.
I can not think of a worst place to install water heaters.
Oil Burner/Boiler & Tankless Water Heaters rjordan392 HVAC 6 01-01-2013 07:16 AM
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 08:57 PM
Amount of hot water when heaters plumbed in series? TLockwood Plumbing 13 02-05-2012 08:13 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 06:52 PM
