Two Drains, One Trap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2008, 10:32 AM   #16
Journeyman Plumber
Ron The Plumber's Avatar
Originally Posted by tigerbalm2424 View Post
This work?
ok, if I understand whats going on , my venting in this diagram wont work, right. Or would this work?
Did not see this one you made, this will be fine providing there is no sink on the line coming from the upper floor.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 01-20-2008, 10:36 AM   #17
Journeyman Plumber
First, I want to say thanks for the continued help with this!
Ok, so lets do it this way. Here is a diagram of what I can see for the plumbing in this area of the house. The upstairs is finished so I cant see whats in the wall. I went outside and the only vent stack coming through the roof in this area looks to be 3" or 4" diameter.
All I need to do to finish the bathroom is figure out the sink drain. If I understand Ron correctly, this red would be what I would need to do to add a back to back sink(correct me if I am wrong). Is there any way to do the back to back sink without needing to tie back in above the upstairs sink drain?
Thanks again guys!
Works for me, I'd rather see you replace that lower tee with a wye, will make it easier to clean the line out if needed, a tee can cause a sanke to gp up even you you don't want it to, wye will make it go in the direction intended.
Old 01-20-2008, 10:41 AM   #18
It looks like the pipe on the right is the vent for the lower tub/shower . If it is you could tie your new vent back into it above the bathroom ceiling (space permitting), then you wouldn't have to mess with the upstairs bathroom.
Fitter is offline   Reply With Quote
Old 01-20-2008, 10:43 AM   #19
Journeyman Plumber
Yes you could do that if there is room inside the will past the toilet stack, or ceiling if there is room.
Old 01-20-2008, 10:46 AM   #20
Rewards Points: 324
So, like this?
tigerbalm2424 is offline   Reply With Quote
Old 01-20-2008, 10:51 AM   #21
Journeyman Plumber
Works for me
Old 01-20-2008, 10:53 AM   #22
Rewards Points: 324
Works for me
Thanks both of you guys!! Time for a HD run!
Goodman - pressure switch/condensate trap jrmac HVAC 4 09-07-2009 04:49 AM
drains are backing up eleven22 Plumbing 19 12-20-2007 09:21 AM
Older sewer w/ backwards trap Gregad Plumbing 4 08-21-2007 08:12 PM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 07:30 PM
Testing Drains bjr23 Plumbing 10 05-09-2007 12:30 PM
