Is Twisting A P Trap To Offset/redirect It Ever "too Much"? See Pics... - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2014, 05:55 PM   #1
157
Is twisting a P trap to offset/redirect it ever "too much"? See pics...
I have a odd situation where the drain hole has to be a bit forward in the cabinet because of the foundation sill below. This, combined with a AAV, is causing the reach of the trap to be really far back in the cabinet. If I "twist" the P trap so it almost overlaps, it aligns with the hole.
Is twisting the P trap ever "too much" and will cause drainage issues? Should I just do a offset (65/65) with the drain coming up to put it further back in the corner to alleviate the P trap twist?
I can't post photos yet I guess so here are the links (take out the space):
http: //i.imgur.com/iZNGDg0.jpg
http: //i.imgur.com/tRKsGajl.jpg
157 is offline   Reply With Quote
Old 03-27-2014, 06:37 PM   #2
Rewards Points: 218
Welcome to the forum 157. Try introducing yourself a few more times and you'll be able to post pics. I think you need 10 posts.
Have to see a pic what your talking about for sure, but the p-trap should be fine.
jmon is offline   Reply With Quote
Old 03-27-2014, 06:48 PM   #3
Rewards Points: 12
I've posted the pics for you.
Is twisting a P trap to offset/redirect it ever "too much"? See pics...-izngdg0.jpg   Is twisting a P trap to offset/redirect it ever "too much"? See pics...-trksgajl.jpg
Dan
djlandkpl is offline   Reply With Quote
The Following 2 Users Say Thank You to djlandkpl For This Useful Post:
157 (03-27-2014), jmon (03-27-2014)
Old 03-27-2014, 07:18 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 442
As long as the trap is vertical you're OK, But I would replace the 90 with a tee and put the AAV on top of it- as high as possible
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (03-28-2014), jmon (03-27-2014)
Old 03-27-2014, 08:08 PM   #5
Rewards Points: 1,770
AAV only have to be 4 inches above the trap he has got a manufactured one. It's fine good job.
Old 03-27-2014, 08:10 PM   #6
Plumber
Rewards Points: 442
My neck of the woods it is as high as possible.....
Old 03-27-2014, 08:20 PM   #7
There self sealing if the drain does block the AAV is supposed to clam shut not letting water enter it. We do require you to put it high on a disposal discharge because it is a forced discharge when in operation. That same line also has to have a vent to air somewhere now. We learned a few hard lessons.
Old 03-27-2014, 08:35 PM   #8
157
Thanks all for the feedback — very much appreciated. The AAV is combined with the same manufacturers trap kit (Rectorseal), so I'm hoping the height and placements is appropriate.
The Following User Says Thank You to 157 For This Useful Post:
Old 03-27-2014, 10:34 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I would lose that configuration as it uses up too much room in the cabinet.
Use a couple of 45s and move the vertical pipe back in the far right corner. Put a tee on top of the vertical and go up for the AAV. Use a regular trap to connect into the tee.
Coastal South Carolina
Old 03-27-2014, 11:04 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 990
Seen many a floods from a second story back up,,, some municipalities will not let you use them in a commercial buildings, condos rentals etc, that have multilevel's..... That's here not sure anywhere else..
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-27-2014, 11:21 PM   #11
Plumber
Rewards Points: 442
Idaho has only recently approved them in residential remodels involving remote fixtures such as basements
In new homes- only island sinks may have AAV's
Not allowed in commercial
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 03-28-2014, 07:55 AM   #12
Rewards Points: 582
here in pa we too put them as high as we can...its a good practice...why... we see... many where little rubber seal leaks ..alot...makes small mess...imo on aav higher is better
Old 03-28-2014, 07:00 PM   #13
Manufacture specs and IPC code is 4 inches above the trap manufacture install instructions. Stack AAV are no longer allowed in Ohio.
The Following User Says Thank You to Ghostmaker For This Useful Post:
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 06:45 PM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 07:16 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
Please help with p trap (pics) techprincesse Plumbing 12 06-03-2011 04:17 PM
