Twin Water Heaters Installed - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2012, 08:53 AM   #1
Pretending to be Retired
My Son-In-Law called me yesterday and said one of his water heaters was "gushing" water all over the crawl-space and "what do I do now?"
We crawled under the house and found two water heaters, fat low ones, installed. Looks like they are both connected to the same cold water pipe and the same hot water pipe. There was only one shut off valve installed on the cold water side of each tank.
Questions: Does this sound right? Why only one valve on each tank? It appears the tanks are installed in parallel. How does the water flow in this type of install? I mean the call for hot water comes and does it flow out of both tanks equally?
Plumber can't make it out till Monday (he is away from home) , so I went out and bought a shut off valve (type that just slides on; maybe called Shark Bite?) and installed it on the hot water pipe isolating the leaking tank for the time being.
BigD9 is offline   Reply With Quote
Old 04-08-2012, 09:11 AM   #2
DIY staff
Rewards Points: 7,174
Shut off valves are installed on the cold only for safety reasons---if the tp valve (temp/pressure) were to fail to open----and both in and out pipes were closed---the tank could explode---
You tube has a funny video from 'myth busters' where they launch a water heater three stories high---
Your temporary bypass will be fine as long as the gas is turned off to the bad unit---Mike---( You sound smart enough to have that one figured out already)
Old 04-08-2012, 10:33 AM   #3
biggles's Avatar
as long as the hots are both coming off the seperate tanks that is OK... if the hot from one goes to the cold of the other that would be in series installer might installed hot water shut offs but not normally..cold is common so you don't shut the house feed
Old 04-08-2012, 11:01 AM   #4
Experienced
Jackofall1's Avatar
I think Mike meant to say "Failed closed" if it failed open there wouldn't be any pressure build up....
Mark
Old 04-08-2012, 11:20 AM   #5
DIY staff
Thanks--My spell check is also out of wack---you will be able to see what a bad speller I am---English--who can spell whose words?
Old 04-08-2012, 11:33 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
That's the theory, but i've seen a lot of parallel installs that don't work right, because the hot water outlet from both tanks has to be the same distance from the main, otherwise you'll only pull hot water from one tank.
Journeyman Plumber
Old 04-08-2012, 02:06 PM   #7
Oh No! I forgot to turn off the gas. Oh crap. I figured since the water heaters are electric I didn't need to turn off the gas.
Sorry about that, I just couldn't resist. Ok, maybe a little humor is needed on a day like this. Seems like I just can't get away from plumbing problems lately. Just replaced the "guts" on 3 toilets since two of them suddenly went bad. Then just after a I wrote the above description of a parallel water heater my CEO said "honey, we have a problem. The dishwasher is leaking water all over the floor!" I just love how she says "WE". Turned out the discharge hose sprung a leak where the installer overtightened the worm clamp and cracked the thin plastic discharge tubing.
I saw that Myth Buster show. They had to really work on the heater to get it to go, but when it did...... And yes, I actually shut down the leaking tank electrically and water supply. I told my SIL the "real" plumber would probably not like my Shark Bite fitting, but it was all I could come up with on short notice. I was afraid of attempting to solder the pipe shut since the house is a two story house and I figured I could never get enough water out of the pipes for an amateur like me to successfully solder a cap on the hot water pipe.
That's the theory, but I've seen a lot of parallel installs that don't work right, because the hot water outlet from both tanks has to be the same distance from the main, otherwise you'll only pull hot water from one tank.
They have the same diameter 3/4 inch copper pipe and same lengths. So I guess I was concerned for nothing.
Interesting comments all. Thanks!
The Following User Says Thank You to BigD9 For This Useful Post:
oh'mike (04-08-2012)
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Have to replace 2 water heaters in house we're buying...help! housenewbie Plumbing 9 01-09-2011 12:55 PM
tankless water heaters rditz Kitchen & Bath Remodeling 0 01-06-2011 10:35 AM
installed new hot water tank and now we only get hot water if 2 sinks on at same time Terryh Plumbing 5 07-26-2010 04:54 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
