-   -   Twin Impeller Shower Pump Connectors (http://www.diychatroom.com/f7/twin-impeller-shower-pump-connectors-3740/)
snowman23 09-01-2006 03:32 AM
Hi and good morning to everyone
I am looking for some advise please, I have installed a shower pump under my bath and connected the pump up to the mixer taps and pipe work by using flexiblle tap connectors. I later realised that I was suppose to buy the specific flexible connectors designed for the pump. The only difference I can see is that the specific flexible connectors have plastic screw on fittings and have plastic push on fittings to the pipe , where as the tap connectors i have used have metal screw on connnectors and compression fittings to the pipe .
I have not turned the pump on yet as i am not sure if it is safe to run the way I have rigged it up. I am just running the water form the gravity for now.
Please can someone advise me if it is ok to run the pump as I have installed it or if I should buy the correct fittings and install it again.
Look forward to your replies...
Jimbob 11-11-2007 04:33 AM
You should always use the right parts for the job, especially when it comes to water.
The flexible pump connectors serve 2 purposes.
1. Reduces pipe vibration to and from the shower pump.
2. Has no nasty tight bends and thus helps the flow rate.
Its up to you but I would go back to where you bought the shower pumps and get the correct connectors.
What type of shower pump is it? As I fit Salamander shower pumps and they always come with the connectors in the pack.
