Turning Off Electric Hot Water Heater For Six Months - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2013, 11:03 AM   #1
turning off electric hot water heater for six months
when turning off a hot water heater for an extended period of time, say six months, can you leave it full or should it be drained.
phurgy is offline   Reply With Quote
Old 02-26-2013, 11:24 AM   #2
leave it full then you don't have to remember to refill it before you turn the power back on.
Old 02-26-2013, 12:12 PM   #3
joed's Avatar
Rewards Points: 12,896
Unless there is a freezing risk, leave it full.
Old 02-26-2013, 12:31 PM   #4
r0ckstarr's Avatar
Rewards Points: 2,052
After the 6 months have passed, should they drain it or flush it before using the water that has been stored in it?
r0ckstarr is offline   Reply With Quote
Old 02-26-2013, 12:36 PM   #5
We do both leave it full and empty during cold months.
I turn the breaker at the panel off and the disconect at the heater. I use a peice of wrie to to lock the disconnect with a tag reminding to fill and purge the air out of the tank!
Hardway is offline   Reply With Quote
Old 02-26-2013, 12:37 PM   #6
No unless there is a rust problem.
Old 02-26-2013, 05:24 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... At my river house, I flip the breaker, 'n drain it 'bout October,...
Usually by May it's refill, 'n repower it time...
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
Not Enough Hot water in the shower from a 40 Gallon Electric Hot Water Heater. rcake Plumbing 10 06-10-2011 12:20 PM
Turning off electric water heater when not in use? skipjack Green Home Improvement 10 03-08-2011 09:02 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
