#1 |
Turn off Propone Water Heater to Save $$
Single guy living in 3000+ sft home with a Bradford White Defender Safety System Propane Water Heater (40 gallon I think). Since the only real hot water used / needed is for a 10 min shower every morning does it make sense to shut it off before going to work in the morning and turning it back on say at 6 pm every evening to save money or will it use more propane to heat up than to leave it on 24/7 to maintain the temperature? I know that a on demand system would make more sense but that would be down the road.
#2 |
I don't think you will lose that much heat from standby to make that a good idea.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
I agree. You need to keep the pilot on to reduce rusting problems, and turning it down during the day will not save much.
#4 |
What you save by turning it off will be lost when it has to heat the whole tank later.
If you have never made a mistake, you haven't done much. |
| Display Modes | |
| Kitchen Faucet Cold Water Runs Hot | Mthrboard | Plumbing | 8 | 08-02-2009 07:59 AM |
| Electric Water Heater | GTSRider | Plumbing | 31 | 12-07-2008 12:30 PM |
| Wiring to a water heater | bvsmith_1974 | Electrical | 3 | 09-03-2008 04:32 AM |
| No Expansion Tank for Water Heater | vasanvasan | Plumbing | 4 | 12-14-2007 12:16 AM |
| Periodic release from (I think) the T&P valve on the water heater | alexz | Plumbing | 3 | 08-15-2006 11:31 AM |
