Old 02-22-2012, 01:52 PM   #1
tub wont drain. Is the problem up or down?
Greetings!
I have a bathtub/shower drain on the 2nd floor of my house that is clogged (only drain with a problem in the whole house). I have replaced the metal overflow, drain and trap with PVC but still no luck. The remaining cast iron metal pipe is horizontal for about a foot or two, and then goes into a tee. I have pushed a 25 foot snake through this pipe but still no flow. The part of the tee that goes down meets up with other drain pipes less than 25 feet from where I am snaking. Also my wife said she thinks she heard me snaking loudest in a room above the bathroom. I can think of only 2 possible situations at this point.
1. my clog is below the tee and my snake is going upwards at the tee.
2. my clog is in the vent and my snake is going downwards.
If my clog is below the tee how do I make my snake go downwards? Is it possible that a clogged vent would not let the tub drain? I have a big cast iron clean out in the basement but the other pipes meet up with the pipe that I snaked before the clean out.
Thanks for your help everyone.
homeowner432423 is offline   Reply With Quote
Old 02-22-2012, 03:32 PM   #2
call me E
TheEplumber's Avatar
Sounds like your going up the vent instead of down- happens sometimes.
I usually don't have any cutting heads on my smaller cables. This allows me to put a small 45 degree bend in the cable. When inserting the cable, orientate the bend to the tee. It should the drop down the tee to the blockage. There's a good chance the obstruction is right there and forcing the cable to go up the too versus down.
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (02-25-2012)
Old 02-22-2012, 03:53 PM   #3
Do you mean you cut off the end of the snake that opens up a little (about the size of a thumb)?
Old 02-22-2012, 04:43 PM   #4
try a couple times to see if you can get it to go down the other thing is does the vent go straight up and out the roof if so you can run snake down from there i have had to do that before
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 02-22-2012, 11:01 PM   #5
Master Plumber
Javiles's Avatar
You’ll need a drop head on the end of that cable for that situation.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 02-23-2012, 10:30 AM   #6
Doing it myself
Alan's Avatar
The only thing I see missing from your original post is where you pulled the stopper for the tub and yanked a bunch of hair out of the lower shoe.
If you did already do that, you need a drop head, as suggested above, and possibly a different size cable depending on what you're using.
Journeyman Plumber
Old 02-23-2012, 01:02 PM   #7
No hair, just rust. I'm using a 25 foot long 1/4 inch snake attached to my drill. Last night I got it to go downwards by bending the head a little. It drains but its slow. No slime on the snake, just rust. I guess I just need to do it a few more times.
Old 02-23-2012, 01:28 PM   #8
call me E
Please clarify- Did you replace all of the waste and overflow, including the drain shoe and ptrap?
Old 02-24-2012, 10:55 AM   #9
yes. All that is left from the original is the tub and a cast iron pipe sticking out horizontally from the wall/ceiling.
Old 02-24-2012, 03:01 PM   #10
call me E
If you have a trip lever tub drain, make sure the linkage is adjusted properly
Old 02-25-2012, 09:20 PM   #11
The new drain is the lift and turn kind. No linkage to fiddle with.
Old 02-25-2012, 09:49 PM   #12
retired elect/hvac/plumb
plummen's Avatar
Thats what I do,then bend a 45 degree bend into the end of the cable
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-25-2012, 11:16 PM   #13
call me E
Same here. Nobody at our shop has heads on their small cables
Old 02-26-2012, 12:54 AM   #14
Doing it myself
Alan's Avatar
We don't have small cables at our shop because some @#$^#^# keeps using them to snake mainlines.
Journeyman Plumber
Old 02-26-2012, 03:45 AM   #15
plummen's Avatar
Now thats funny!
Tags
drain, overflow, snake, tub, vent
Blocked Drain Problem milkman2010 Plumbing 6 07-02-2011 08:23 PM
Vessel Sink Drain Problem Howsuenate Plumbing 6 07-01-2011 10:10 AM
Furnace drain problem jkennedy99 HVAC 21 01-27-2010 07:52 AM
Kitchen Sink Drain Problem Spark General Discussion 9 06-15-2009 12:00 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
