Tub Or Wall Bars For Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-13-2012, 03:04 PM   #1
tub or wall bars for bathtub
several yrs ago i had my 50 yr old tub and tile covered with an acrylic liner. at the time no grab bars installed. since then i've had plumbers and other workmen in and always asked if they would put in grab bars and the answer is always 'no i don't know what's in back of the liner'. recently saw tub bars and wondered if that would do....i can install myself. are they safe and how would it impact the liner on the tub. at the moment, i hold onto the bathroom door getting out - not a good idea
grandmeme is offline   Reply With Quote
Old 06-13-2012, 03:10 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by grandmeme View Post
... ' i don't know what's in back of the liner'
And no one reading your post here will know either.
They're plenty safe and the tub liner isn't the question.
OK... btw, what do you propose attaching them to?
Old 06-13-2012, 03:28 PM   #3
tub bars
they fit over the tub and pressure holds them...that's why i wondered about the liner. they are not the ones that are screwed into the walls.
Old 06-13-2012, 04:07 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 450
When grab bars for tubs, toilets or any other application are installed you must make sure there is backing inside the wall for the mounting hardware. Sheetrock, tile or tub liners will not do. That's why your plumbers didn't do it.
Imagine yourself falling and all that sudden force when you grab the bar. If its not anchored to studding or backing you'll find yourself on the floor holding a grab bar in your hand.
Old 06-13-2012, 06:38 PM   #5
MarginallyQualified
Getting back to this point...
what is behind the tub? on the opposite wall from the bathroom?
Ideally... that'll be a closet.
If so then the reinforcing hardware and such that proper grab bars require can be done from there with a minimum of work (perhaps six small holes) affecting the liner. Some drywall repair but no liner impact.
However... if it's an exterior wall or maybe something like your living room with hoity toity expensive flocked wallpaper you don't want to disturb... well, lets say that a lot more that would affect the liner is needed.
hth
Old 06-13-2012, 07:18 PM   #6
Rewards Points: 13,270
Find the studs above the enclosure, transfure the the lines down the wall of the enclosure. That's where the rails can be screwed to.
Old 06-13-2012, 07:19 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Usually there is a section of wall above the surround that I can use a stud finder to find the studs. I use a level to drop a line down the wall to identify the studs behind the liner or tile. Drill thru the liner into the stud and secure your grab bars.
Coastal South Carolina
Old 06-13-2012, 08:29 PM   #8
DIY staff
Rewards Points: 7,174
You need that tub mounted safety grab---I say, just install it over the tub edge and tighten down the clamps---
If it shortens the life of the overlayed liner--but keeps you from getting hurt--so be it.
Safety first.---Mike---
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
