#1 |
Is this tub vented properly?
Hey all I am looking for some help on my tub venting. The house is 40 years old. The picture attached is what the plumbing looks like. I have had the toilet off and run water through so I know the sink and the tub both connect under the toilet and then go to the septic.
Both the sink and the toilet are fine and I think they are adequately vented based that the roof vent is on the same wall with them. The tub doesn't have a vent and its pipe goes across the bathroom floor then ties into the toilet. When you shower, there is an inch or so of water in the shower and the tub gurgles through the overflow vent. I have made sure no hair, etc is clogged on the X part of the drain. Would adding an air admittance valve on the pipe where the tub overflow connects to the drain give me more venting for better draining? Thanks a lot |
#2 |
Master Plumber
depending on your code! IPC its piped correctly, should be connected to the stack above the toilet below the sink. distance no more than 8 feet from the trap to the vertical, AAV will not help, that line may need a good cable cleaning also what type of drain assembly is in the tub shoe and overflow, what material is the line and is it still pitched properly. could have multiple problems other than venting.
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Sealed or vented? | stevenmarston | Plumbing | 2 | 11-17-2010 03:51 PM |
| cathedral ceiling vented or not in canada | alberta boy | Building & Construction | 2 | 03-24-2010 07:32 AM |
| Tub shower not operating properly | Zinger | Plumbing | 3 | 02-21-2010 10:51 AM |
| Adding vented soffiting | dmozingo | Building & Construction | 10 | 07-22-2009 01:43 AM |
| Air return through vented doors | yam | HVAC | 7 | 08-22-2007 12:37 PM |
