Tub Surround Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-10-2012, 09:04 PM   #1
Solutions (handyman)
Rewards Points: 364
Tub surround question
I am installing a new tub and surround. I believe the tub does not have drywall behind it, but the surround does. Should the drywall for the surround be primed or painted before the surround is attached or can it be attached to the unfinished surface?
Mark Harvey is offline   Reply With Quote
Old 06-10-2012, 11:12 PM   #2
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
any time iv'e installed 1 piece surround or tub w/3 walls you set to rough stud then rock to it.
wctekkk is offline   Reply With Quote
Old 06-11-2012, 08:03 PM   #3
Rewards Points: 1,506
I don't think it matters whether the wallboard is primed or painted first. Water and moisture should not be getting back there when the seams are properly caulked.
The glue used to attach the tub surround panels to the wall will bond slightly better to unfinished drywall.
The Following User Says Thank You to AllanJ For This Useful Post:
Mark Harvey (06-11-2012)
Old 06-11-2012, 08:45 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
There shouldn't be any drywall used around tub, use cement board but after the tub is in.
JetSwet is offline   Reply With Quote
Old 06-11-2012, 09:46 PM   #5
Rewards Points: 109
Use cement board after you install the tub.. There should be a lip on the tub the cement board can rest on..
mchipser is offline   Reply With Quote
Old 06-11-2012, 10:02 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
Yes you want that space so it sits on the tub lip.
Old 06-12-2012, 12:34 AM   #7
Rewards Points: 276
What type of surround are you installing. There is the type that glues onto a wallboard surface- can be dry wall or cement board. But the the other type is much more rigid, usually is part of a set with the tub and mounts directly to the wall studs.
Jim F is offline   Reply With Quote
Old 06-12-2012, 06:43 AM   #8
Rewards Points: 364
As to the type of surround, I'm not sure at the moment, other than it's a five piece unit. I have also heard, recently, that cement board is not required and even the moisture resistant isn't all that it's claimed to be. The reasoning is that direct moisture should reach the board ... because of the surround, and humidity isn't enough to create any issues. Any comments?
Old 06-13-2012, 02:24 AM   #9
In my opinion keep the things simple now there are few who do go for cement board but it does not make much difference I would rather say that go with the advice of Allan.
paul parker is offline   Reply With Quote
Old 06-13-2012, 11:47 AM   #10
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
If all else fails, read the directions.
What does the manufacturer recommend?
Old 06-13-2012, 02:37 PM   #11
Pro
JetSwet's Avatar
Rewards Points: 502
If you go with a fiberglass surround then it gets attached to the studs then sheet rock on top and around it.
If you just put a skirting sheet then it gets liquid nailed to the Sheetrock or cement board.
1/8 ply behind tub surround? lucky6man Kitchen & Bath Remodeling 2 02-15-2012 09:38 AM
Delta shower faucet acrylic surround question rboutin2 Plumbing 2 10-05-2011 10:28 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
shower/tub surround prep. question mayhem69 Remodeling 7 08-03-2008 12:28 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
