Tub Surround - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2009, 04:50 PM   #1
Post
Tub Surround
I have installed a new tub surround and it does not go to the ceiling, how do I trim it out?
slsbmo is offline   Reply With Quote
Old 01-04-2009, 05:26 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Green board from the nailing flange to the ceiling. Finish it with tape and mud then paint. Or if you want to tile up to the ceiling then cement backerboard from the nailing flange to the ceiling then tile on top of that.
JDC is offline   Reply With Quote
Old 01-05-2009, 09:58 AM   #3
Question
Tube Surround
Thank you very much! I have put up greenboard and painted but what do I do about where the tub surround ends, it's just a straight cut and then painted wall? Don't I need something to make it look more finished?
Old 01-05-2009, 10:09 AM   #4
Rewards Points: 682
Put a line of silicone on the edge between the green board and the surround. It looks good, and more important seals out moisture.
darsunt is offline   Reply With Quote
Is H20 resistant sheetrock ok behind an f-glass surround? Jeffrey H Plumbing 6 11-01-2010 06:30 PM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 04:14 PM
Tub Surround that has rounded corners jknic Remodeling 2 09-11-2008 05:35 AM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 10:52 PM
