Tub Spout Splashing Water Back. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2013, 07:39 AM   #1
ajm
Tub spout splashing water back.
Hello, I had a couple questions and some pics below, enjoy the pink tub.
In my rental property I ended up replacing tub spout with slip on. I secured loose pipe And realized it was not square out from wall leaving a gap at top of spout, used a Sioux chief smart spout figuring it would pull tight. It seemed to work. Any experience with that spout? A little worried spring inside will end up rusting. Anyways, the water shoots back over trip plate as the pic shows below. Initially was thinking it was perhaps the angle and flatness of inside of spout, but now believe it is a water pressure issue? See pic of flow with spout off. Any ideas? Is there anyway to dial down the pressure within the mixer valve? No shut offs in back. Other apartment's pressure is fine . Thanks.
Tub spout splashing water back.-image-1510458196.jpg   Tub spout splashing water back.-image-3161501134.jpg   Tub spout splashing water back.-image-4042130808.jpg
ajm is offline   Reply With Quote
Old 02-22-2013, 02:49 PM   #2
ajm
Any ideas? While I realize I probably should get the pressure checked, do they make any type of screen/insert I can put at the end of the spout to properly direct the water? Thanks
Old 02-22-2013, 02:56 PM   #3
Rewards Points: 13,978
I've never seen one.
I'm not seeing the issue I guess.
It would have been as simple as pulling up a little to bend the copper pipe that sticks out to get it to fit flush or just add some silicone caulking .
My walls always end up with some splash back. If the tile is sealed and the spout is sealed there should not be an issue.
Old 02-22-2013, 02:56 PM   #4
Rewards Points: 42
I think it's the spout. I have the same valve but don't have the splash back issue. It could be the pressure but you aren't supposed to block the flow with the Symmons valve.
Does the pattern out of the spout change if you use the diverted to lower the pressure?
Dan
djlandkpl is offline   Reply With Quote
Old 02-22-2013, 10:59 PM   #5
ajm
Thanks for the responses. The water does hit a smidge lower on the trip when moving diverter to "low tub", but not meaningfully. When I removed shower head force was way less on full shower. I realize its going up hill, but the length of the full flow stream with tub spout off seemed excessive to me and stream was more white/bubbly water. Originally I cut/ground down the existing threaded spout it did the same thing but was definitely less backsplash but still hit trip. If trip is properly sealed perhaps there is little concern, yet I am worried about leaks over time as it's at or above the top of the trip and it's a second floor bath. I may have actually secured the pipe more back from the hole behind the tub to get the original spout to fit tighter. Maybe securing with a little more pipe out from the wall (and trim accordingly) will make a difference? Yet the current spray seems like it even shoots right and left abnormally with either spout. Thx
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 12:47 AM
Water boiler spout leak issue cklnyc HVAC 60 01-02-2012 01:53 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
