Tub Spout Set Screw Missing - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2012, 06:33 PM   #1
Tub spout set screw missing
well its not missing its just not were its suppose to be, i went to change out my spout today looked underneith and the notch is there but no set screw.
i turn the spout and i can see the plastic slip fit thing, spinning with the spout.
wallajon is offline   Reply With Quote
Old 11-05-2012, 07:05 PM   #2
DIY staff
Rewards Points: 7,174
The spout is junk---so get your tin snips and remove the shirt and get that screw out----do not be tempted to pull that off with the screw set to the pipe---you will score the pipe---making it difficult or impossible to get a tight seal===
I always go to the plumbing supply house for a Moen push on spout---the ones I've found at the home stores are a waste of time and money---
How to remove screw stuck in the wood? higv2000 General DIY Discussions 13 06-30-2012 01:40 PM
Input for a Screw Guide Card marriomi Carpentry 5 06-28-2012 11:05 AM
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
Bathtub Spout Replacement cspirit Plumbing 4 03-18-2011 06:39 PM
Removing Delta Roman Tub Spout stanart Plumbing 1 10-31-2010 05:20 PM
