Tub Spout Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2013, 01:21 PM   #1
Tub Spout problem
The Problem:
Tub spout leaking. When shower is on, water sprays out of the rear of the spout where the Allen nut is.
Spout is slip-on type. It was very difficult, but I was able to remove the old spout (which had to be destroyed).
I notice that the slip-on stub out is only 3/4" in length coming out of wall, and the end is chewed up a bit.
No Universal tub spout w/diverter works with a 3/4" slip-on stub-out, that I've found.
Any suggestions would be greatly appreciated.
bmerc5054 is offline   Reply With Quote
Old 02-26-2013, 06:36 AM   #2
I cut the copper pipe as close to the wall as possible.
I soldered on a 1/2" threaded male extension, which now came out of the wall 3/4" total with threads.
I siliconed the opening around the copper pipe.
I installed the Danco Universal tub spout.
It seems to be working fine, and it's tight against the tub wall.
Tub spout splashing water back. ajm Plumbing 4 02-22-2013 10:59 PM
Removal of Tub Spout Remski Plumbing 2 09-11-2012 11:09 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Tub spout diverter problem Chaosdragon13 Plumbing 2 05-28-2008 12:23 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
