Tub Spout Leak, Spout Off, Pipe Leaks - Now What? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2009, 10:19 AM   #1
Tub spout leak, spout off, pipe leaks - now what?
Hey all:
I finally managed to remove the tub spout thanks to some tips I found here, and the leak is still happening out of the bare pipe.
I've got an older (late 80s) shower/tub combo with single handle - probably Moen. There is no plumbing access space on this one, just a wall, open to the room on the opposite side.
Not sure what my next step is - I am thinking it is time to cut into the wall to access the actual valves and stuff. Any advice? If it helps, the house is for sale, so let me know if I should just leave the leak and take something off the price.
annabananamc is offline   Reply With Quote
Old 07-11-2009, 12:50 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You probably just need to replace a Moen cartridge from the tub side.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-11-2009, 01:52 PM   #3
thanks Mike - I hope I can find that thing when I take off the knob plate and get to it. My luck I would drop it inside the wall!
Old 07-11-2009, 02:28 PM   #4
Long-Time DIYer
It's held in by a horseshoe-type clip and it can be difficult to remove sometimes without the cartridge tool, but you should be able to get it out, take it to the store and get a duplicate. It can't fall behind the wall normally. Just make sure that you put the new cartridge in the exact same way that the old one was seated.
Good luck!
Mike
Bath tub spout leak issue abc Plumbing 1 01-26-2009 01:04 AM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 03:41 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
pipe leak & sheetrock damage santogr General DIY Discussions 2 03-04-2007 01:44 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
