Old 05-07-2007, 09:38 AM   #1
Default Tub Spout Gap??!? Please help.
We recently purchased a house that needs some "fixing up". We replaced the shower head and my boyfriend said the pressure was low and he thought it was because the pull on the tub spout wouldn't lock into place and stop all the water from coming out of the spout. Went to the store and bought a universal spout but there is a half inch gap between the tub wall and the spout. Why??!? Is it that this part is not universal, or are we supposed to remove some of the peices? It looks like we could remove the brass nut but then we have no way to screw it in. Sorry if this is a dumb question, but I could use the help! Thanks!
Mayzee1 is offline   Reply With Quote
Old 05-07-2007, 01:54 PM   #2
Handyguy
Brik's Avatar
Is it a thread on style spout or does it slide on to a copper tube? If the latter you may need to trim a bit of the copper off. If its a thread on style you may need a different sized 'nipple' behind it.
http://www.handyguyspodcast.com
Brik is offline   Reply With Quote
Old 05-07-2007, 02:41 PM   #3
Yes, it seems to be just tubing that you slide it onto, no threads. It's ok to just trim some of the pipe off, and we won't cause any trouble? Thanks!
Old 05-07-2007, 02:46 PM   #4
Yes, just trim of the amount needed to let the spout go to the wall. Make sure there are no sharp edges on the pipe because there are rubber "O" rings that make the seal to prevent the water from leaking back to the wall.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-07-2007, 02:48 PM   #5
Handyguy
Brik's Avatar
Right, use a tubing cutter.
Here is the first one I found via google
http://www.toolbarn.com/product/ridgid/32985/
Your home cent will have a cheaper one for about $5 that will do the job. Or, just get a longer spout.
Old 05-07-2007, 04:47 PM   #6
Do they make more than one kind of "universal" spout then? The one I purchased was the only one I could find. Thanks!
Old 05-07-2007, 05:09 PM   #7
Handyguy
Brik's Avatar
There are lots of spouts that fit 1/2" copper stub outs.
I recently installed this one from Kohler.
http://www.us.kohler.com/onlinecatal...6+Bath+Spouts#
The rough-in guide says the 1/2" copper should be 2 1/2" min and 3 1/2" max out from finished wall. Comes in various finishes. This one is "universal" in that it works with 5/8"OD copper (1/2" copper), which is what you apparently have and also 1/2"NPT (pipe thread).
Old 05-07-2007, 05:32 PM   #8
Thanks so much!!
More On This Topic
Hi! I'm Matt Cail on behalf of Expert Village. I'm here today to tell you how to set up and play bobbing for apples. In addition to making sure the contestants are properly positioned, there are a couple of other tactics which are questionable. Other... Read More »
Clawfoot tubs were once the only option people had for bathtubs. Then, for a time, they represented affluence before going out of style for a half century or so. Now they're back, but many people find that repairing and updating their clawfoot tubs can... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Hi, my name is Evan Blankenship with Expert Village. I'm going to be teaching you how to pop shuvit. Now that you got pop shuvit's down on flat ground you can pop the board, get a good foot position, you know how to catch it and you know how to land on... Read More »
All right, now that we've got the base of our tee-pee setup, we can move into some even bigger logs. And these are ones that we've actually split before we started shooting. And they are just, as you can see the wood is fairly dry. And these are anywhere... Read More »
Long Tub Spout ? mahjohn Plumbing 0 08-16-2007 09:35 PM
Bathtub tub spout Diverter broken? tripower Plumbing 5 06-24-2007 08:44 PM
Shower head not working, having trouble with replacing the tub spout keyser soze Plumbing 26 06-12-2007 09:39 PM
Teflon tape adequate for spout diverter? darsunt Plumbing 1 06-05-2007 03:50 AM
Need help with tub spout sherlock Plumbing 1 10-25-2005 05:19 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
