Old 02-05-2013, 12:25 AM   #1
Tub spout diverter operation question
I'm just wondering how a tub spout diverter is supposed to operate and when it is considered operating incorrectly (and needs replacement).
Typically, you pull up diverter to use the showerhead, and push down (if needed or not in down position currently) to use the tub spout.
* if spout leaks a lot when diverted, time to replace
* if diverter stuck or hard to use, time to replace
The replacement spout I bought to replace old spout says the diverter returns (eventually) to the down position after water flow is stopped. And you pull up on diverter after water is on to switch to showerhead.
Just yesterday, the diverter didn't fall back down long time after water was off (I didn't close the faucets to to the "tightest" off, but was pretty much off and I see no water dripping or water pressure noise). So is that ok, or it indicates a problem?
Also, I haven't used spouts with diverters in a while and was under impression before replacing spout that you could also pull up on diverter before turning on water. Is that ok or does that cause problems?
daluu is offline   Reply With Quote
Old 02-05-2013, 07:49 AM   #2
Super Moderator
Those diverters wear out or get all limed up and corroded---
On most , water pressure holds the flapper closed--and a small amount of water escapes around the flapper to allow the water in the spout to drain when the water is shut off---
When they allow to much water to pass---it's time to clean with CLR or replace the spout.
I have never had any luck with the 'universal' spouts at the big box stores--junk--all of them.
Get a name brand spout from a plumbing supply house.
There are three types----so remove the spout and take it with you.
1. Push on---slides over a copper stub out--held in place with an Allen screw from underneath.
2. Threaded---fits over a threaded 1/2" nipple---unscrew to remove--you may need to replace the nipple with the correct length to fit the new spout.
3. Delta----this one slips on and is held with an Allen screw--a brass fitting with rubber O rings will be soldered to the copper stub out.
oh'mike is online now   Reply With Quote
Old 02-05-2013, 08:54 AM   #3
Roofmaster
I just replaced mine with a Ball valve. Got tired of the loss of pressure to the head, and water on the floor from overspray. It aint pretty, but I dont GAS! It works now.
" A lot of men build things, and a lot of things fall down "
Old 02-05-2013, 10:31 AM   #4
Doing it myself
Alan's Avatar
I got a replacement one from american standard for free, and it leaked a bit from day one.
It's not a perfect system. That's all I can really say.
Most people don't want to spend the extra cash to put an in wall diverter, so that's what they get.
Journeyman Plumber
Old 02-05-2013, 12:09 PM   #5
Tubs using a spout diverter have a simple T connection from the faucets/valve and between the shower pipe and the spout feed pipe.
Water goes to the spout by gravity. When you pull the knob, the spout is blocked and then the water goes up to the shower.
Most spout diverters are mechanically designed to drop open when the water is turned off, thus preventing a surprise cold shower to the next person using the tub. Unfortunately corrosion or sediment often causes it to not drop open by itself.
As a rule of thumb, a small drip from the spout when you are using the shower is not considered abnormal or a need for immediate replacement.
It is a good idea to cut a notch at least 3/8 inch square at the bottom of the spout where it would meet the wall. This prevents water that gets between the spout body and the pipe inside, perhaps from an imperfect joint with the feed pipe, from going into the wall and rotting out the wallboard behind the tiles.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
AllanJ is online now   Reply With Quote
Old 02-06-2013, 12:00 AM   #6
Can you elaborate on that or provide photos? I don't quite get what you mean, though I do get that you mean leak prevention. What to cut exactly?
I read online somewhere there was suggestion to caulk around the hole where the spout valve/pipe protrudes out the wall so that it blocks water entering the wall through the pipe as you mentioned. Though I assume that works best only when the hole is only slightly bigger than the pipe coming out the wall.
Old 02-06-2013, 08:00 PM   #7
The notch is made in the base of the spout. If water got inside the spout, it would drain out through the notch.
Old 02-06-2013, 08:16 PM   #8
Thanks for the info Allan. The universal spout I have already has the notch to accomodate push in spouts that have a screw to secure the copper pipe the spout attaches to, which typically seems to be in that location, though mine was a threaded screw in spout one instead.
Removing Stubborn Tub Spout 347Cougar Plumbing 6 12-27-2012 04:12 PM
Tub Diverter Spout won't fit! Janis Ingebrets Plumbing 1 05-04-2011 06:00 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 11:53 PM
Removing tub spout dummy14 Plumbing 20 11-17-2008 12:48 PM
