Tub Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-22-2010, 01:11 PM   #1
tub spout
Hello All,
I am nearly finished creating a bathroom upstairs in our home. My issue is concerning the installation of the tub spout. I have tightened the spout (threaded) quite tight by hand and the spout is facing upward! I am worried that if I tighten it too much, I will break the solder seal in the threaded copper supply pipe.
Any thoughts?
Thank you.
treefrog is offline   Reply With Quote
Old 07-22-2010, 03:22 PM   #2
DIY staff
Rewards Points: 7,174
You need a shorter nipple,obviously.
Don't over tighten that You will break something.
If you can't find the size you need----
Make the nipple out of 1/2 inch copper and 2 male threaded fittings.---Mike--
Old 07-22-2010, 04:04 PM   #3
lloydb's Avatar
Well if the spout is where it needs to be in relation to the tub wall, I'd just back it off a half turn and point it down. There isn't much pressure in a tub spout as it either flows out the end (or up to the shower head if there is a diverter).
Broken Arrow hvac Broken Arrow Air Conditioning
lloydb is offline   Reply With Quote
Bathroom Tub Diverter Spout karenmc Plumbing 3 07-24-2009 03:23 PM
Frustrating bath spout removal problem martinvancouver Plumbing 6 07-09-2009 12:38 PM
Bath tub spout leak issue abc Plumbing 1 01-26-2009 01:04 AM
Tub Spout Help showerhelp Plumbing 9 11-13-2008 07:15 PM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 03:41 PM
