Tub Spigot - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2012, 12:08 PM   #1
tub spigot
ok. just so you know i know nothing about plumbing. here is my problem. while taking a shower water runs from the spigot. what do i do?
mazee is offline   Reply With Quote
Old 07-06-2012, 12:22 PM   #2
Rewards Points: 12,882
With out know what type set up you have it's hard to tell.
Posting a picture is the best way to clear it up.
Old 07-06-2012, 12:42 PM   #3
Size:  29.4 KBIt's a Moen. I tired taking the faucet off. I was able to get the handle off, but I couldn't get the thing behind it off. I didn't want to break it by pulling too hard. I checked to see if it was the cold or hot water that was running during a shower. It's both, but the hot water more so than the cold. How do I get that back part off? And how do I post a picture? I did take one. I was going to go to HomeDepot or Lowes and ask them how to do it, but they aren't always so helpful.
Old 07-06-2012, 05:45 PM   #4
DIY staff
Rewards Points: 7,174
The center handle is a diverter valve---That is the one that needs attention--after the handle is removed--unscrew the chrome bell shaped escutcheon---then there will be a nut holding in the guts--
The guts should be available at a good plumbing supply house or from Moen (often the parts are free from Moen)
mazee (07-06-2012)
Old 07-06-2012, 05:53 PM   #5
The main incoming water supply needs to be shut off before taking it apart!
Old 07-06-2012, 06:02 PM   #6
DIY staff
It's hot,Joe---a good blast of water would feel refreshing!!
Yes--turn off the water supply---however,no water will come out as long as the hot or cold taps are off--Mike--
Old 07-06-2012, 07:05 PM   #7
I'd bet I'm not the only one that's bump one of the valves by mistake and got wet. lol
Old 07-06-2012, 07:07 PM   #8
I don't know if I'm cut out for this. Lol. Thanks for your advise. I'll let you all know how it turns out.
Old 07-06-2012, 07:09 PM   #9
Wow, I might not be cut out for this lol. I guess I can't really break it any more than it already is.
Old 07-06-2012, 07:11 PM   #10
Lol that would bd the least of my problem. A little water never hurt anyone
Old 07-06-2012, 07:14 PM   #11
DIY staff
The work is not difficult---removing the bell shaped trim sometimes requires a strong hand to remove--once that is off the rest is simple enough.
A rubber strap wrench is handy to have if your hands aren't strong enough to unscrew the bell--
Old 07-06-2012, 07:34 PM   #12
Oh here's a question - does it pull off or screw off? I tried pulling it but it didn't budge.
Old 07-06-2012, 08:45 PM   #13
What if you don't have a strap wrench? Ok we are playing Survivor Bathroom!! And I can only use what's in the house lol - suggestions
Old 07-06-2012, 08:45 PM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 356
Unscrew counter clockwise
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (07-07-2012)
Old 07-06-2012, 08:56 PM   #15
I can break stuff pretty easily . 1/2 ain't bad lol
Outdoor spigot question jaydekay Plumbing 2 10-08-2011 05:16 PM
Outside spigot question... carpenter981 Plumbing 31 10-06-2011 10:28 PM
Freeze Proof garden spigot replacement DK75 Plumbing 8 04-15-2010 08:13 AM
Roman Tub Spigot Problems - Phoenix Corp? bkw Plumbing 1 10-17-2008 04:21 PM
Installing a Hot / Cold Water Spigot dc2295 Plumbing 1 02-25-2008 06:10 PM
