Tub/Shower Supply Riser - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2011, 12:52 PM   #1
Rewards Points: 79
I'm replacing my tub with a wider one so I need to move the control riser so it will be centered. (1" difference) I want to use pex instead of the 1/2" copper.
I called the city plumbing permit office and they told me to supply a isometric drawing of what I planned to do.
I've searched for example drawings but all I can find is drain and venting drawings. I'm wondering if someone has an example of what I would need to submit.
Also, for the tub drain/overflow, instead of moving the floor drain, could I use this offset overflow drain to compensate for the difference.
http://www.woodfordmfg.com/watco/Fle...InnvtrSpec.pdf
RalphPeters is offline   Reply With Quote
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
Supply valve to bath faucet doesn't stop water Kurt123 Plumbing 2 09-05-2010 09:48 PM
New Faucets - Rural Water Well Supply terra3 Plumbing 2 02-25-2010 05:41 PM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 09:21 AM
help w/ duct sizes & new supply locations palex1915 HVAC 0 10-13-2009 07:52 PM
