Tub And Shower Diveter - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-12-2012, 10:09 PM   #1
tub and shower diveter
I bought a house about a year ago, and I replaced the homemade bathtub shower kit in the bathroom. I also put new pipes in the wall that goes to the shower and the tub, but any time the water is turned on, it comes on in the tub and the shower. I thought that the diverter was faulty and has replaced it several times, but that didn't correct the problem. So any time anybody goes to take a bath, they have to deal with the shower also.
mz jackie
mzjackie is offline   Reply With Quote
Old 03-12-2012, 10:20 PM   #2
I've seen this once before and it took me awhile to figure it out.turned out the valve was installed upside down(hot on right cold on left tub outlet on top and shower outlet on bottom.what make is the mixing valve?
plumberman134 is offline   Reply With Quote
The Following User Says Thank You to plumberman134 For This Useful Post:
ben's plumbing (03-12-2012)
Old 03-12-2012, 10:22 PM   #3
Rewards Points: 616
what type of pipes did you use
if pex did you use pex to go from valve to tub diverter the fitting reduce the pipe size which in return creates back pressure that would push up to shower head
can you confirm that shower valve is in the correct up position
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
plumberman134 (03-12-2012)
Old 03-12-2012, 10:54 PM   #4
Rewards Points: 582
seen the same thing before..total messed up install..
Old 03-12-2012, 11:44 PM   #5
Rewards Points: 626
Upside down valve turn it over 180 degrees.
Nailbags is offline   Reply With Quote
