Tub To Shower Conversion - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2013, 10:33 AM   #1
Tub to Shower conversion
I am replacing my tub with a shower stall and going with Koeller product fibeglass pan. The existing plumbing has the overflow for the tub. Should I cut the overflow and cap this section? Also I heard I should replace the drain with a 2 inch drain where would I cut the existing plumbing to do this? Thank you for the advice.
Redding101 is offline   Reply With Quote
Old 01-19-2013, 10:37 AM   #2
Rewards Points: 13,724
How would anyone here know without a picture?
Yes you will need a 2" drain for a shower.
Old 01-19-2013, 10:47 AM   #3
Here the existing plumbing
Old 01-19-2013, 11:40 AM   #4
DIY staff
Rewards Points: 7,174
Open up the piping and see where the 2 inch starts----it might be right there---or it might not exist at all----it is possible the line will need to be replaced over to the nearest larger drain pipe.
Dig out the area around the existing drain and see what you have---
Old 01-19-2013, 12:19 PM   #5
definitely change the drain to 2 inch. you may have to go over near the toilet and cut into the 3 or 4 inch line there to run a 2 inch line for the shower. if you leave the 1-1/2 you will be kicking yourself down the road when you have problems with it.
Old 01-19-2013, 01:23 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 996
Go to 2 inch, the trap may already be in 2 inch if so your good to go, but you cant off set the trap you'll need to relocate it to the new drain area.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-19-2013, 05:03 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Hopefully your drain is on the right end and not center, even then chances are it won't line up exact without some rework.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-19-2013, 07:25 PM   #8
Roofmaster
Rewards Points: 2,210
Yes you will want to open things up some and install a two to the three or whatever is there with a combination fitting or a Y and an 1/8 bend. You will need a vent for which I would also use a combination fitting. It appears that you are starting to get some dry rot in your sole plates which appear to be untreated fir. You will want pressure treated lumber there if you can do it, although it would be difficult and labor intensive at this point. Maybe theres a vapor barrier under there. The good news is that your floor is not too thick, and should be easy to break out. (If you could call that good news) I dont see any clean stone though, which is kind of standard under a slab. Im sure you know this, but shoveling the dirt out and undermining the slab will make removal with a sledge hammer much easier.
Good Luck, John Henry.
Old 01-19-2013, 09:01 PM   #9
Rewards Points: 636
i,p,c. says if shower is below 5.7 gpm a 1 1/2 trap is fine
http://publicecodes.cyberregs.com/ic...9_7_sec009.htm
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Tub to Shower Drain Conversion chris85016 Remodeling 9 01-14-2011 04:43 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
