Tub, Separating Valve And Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2010, 04:23 PM   #1
Tub, Separating valve and spout
I am installing a new tub (drop in, air jetted, no shower) and had planned on putting the faucet on the backside of the tub. This way you weren't hitting you head on it like you would if it were at either end, and you wouldn't have to climb over it to get into the tub. However the tub is 42" wide (not including the enclosure) and it is way to far to reach to turn on the water if the faucet is on the back side of the tub.
So my plan is to have the spout on the back of the tub, but put the control valve at the end of the tub (near where your head would be). Are there any issues with doing this? I plan on using a shower valve and I will have to find an acceptable spout (waterfall type maybe) but that is the only issue I am seeing. So what am I missing?
Thanks,
Bigmatt
bigmatt is offline   Reply With Quote
Whats the Rule of Thumb for Bath/Shower Valve hight K.M.G Plumbing 0 12-14-2009 03:54 PM
Kohler K-304 pressure balancing valve... EdTheDIYer Plumbing 0 05-12-2009 12:18 PM
New shower valve.. No water pressure? wilson5307 Plumbing 2 03-11-2009 11:10 PM
Need to replace shower/tub valve KenDahl Plumbing 4 10-31-2008 01:01 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 09:19 AM
