Tub Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-27-2012, 09:56 AM   #1
Tub replacement
I am replacing my tub with just a shower. Do I need to move the drain to he center and make the drain bigger?
Icarlo is offline   Reply With Quote
Old 07-27-2012, 10:01 AM   #2
DIY staff
Rewards Points: 7,174
Yes--2 inch drain---centered looks best but is not essential if you are building your own pan---
How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
Old 07-27-2012, 05:32 PM   #3
Rewards Points: 582
they make shower units that fit into your existing tub opening with drain on left or right.....but still needs to be 2"......I have seen many ,many times 1 1/2 traps under showers...not code and would not pass an inspection...
Old 07-27-2012, 09:39 PM   #4
Rewards Points: 616
huh if it is not code to use 1 1/2" if it is a shower that uses over 5.7 gpm
yes a 1 1/2 drain can work look at code chart for shower trap size
why is it that people think it wont work if it is not in their local code and why is it that the codes can very so much but both work fine huh must come to someones opinion instead of protecting the health and welfare of the community
http://publicecodes.citation.com/ico...2_7_sec009.htm
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
Old 07-27-2012, 09:46 PM   #5
Rewards Points: 582
hey jay ..good point ...but it is what it is..ben.. you can use it 1 1/2 trap if you want... if I tried it would not pass inspection...
Old 07-27-2012, 09:52 PM   #6
Rewards Points: 616
and yes ben is right get a shower pan with drain on the correct side and then trap will need minimum adjustment just make sure floor joist is not in way if near existing tub drain. might need to check with new shower pan drain rough in measurements before buying.
Old 07-27-2012, 09:57 PM   #7
Rewards Points: 616
i have seen this type of thing disputed in court that their is a difference between code(persons opinion) and protecting the health and welfare of community. and locally it was ruled that protecting the health and welfare of community and that it will operate correctly rules over local code (persons opinion) .
The Following User Says Thank You to jaydevries For This Useful Post:
ben's plumbing (07-27-2012)
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 05:46 PM
New replacement window problems iminaquagmire Windows and Doors 7 11-12-2011 12:56 AM
replace replacement windows theone Windows and Doors 3 10-19-2011 10:16 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 03:24 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
