Tub Reno Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2011, 10:27 PM   #1
Tub Reno Basement
I have replaced an old porcelain tub with a new acrylic. The old tub sat up off the floor further so the new one is bottoming on the drain. I have removed the drain and overflow, cut down the pvc pipe at the T-connector. Replaced it with a new connector drain overflow kit. It still sits about 3/4" up off the floor. I cannot cut under the T-connector any further to drop it more, can I remove the elbow under the connector and shorten it by any means or replace with a shorter elbow? I don't wanna rip it off if it's not gonna get me any further, I don't want to have to shim up the tub either. Thanks!
spike1985 is offline   Reply With Quote
Old 11-09-2011, 05:50 AM   #2
DIY staff
Rewards Points: 7,174
Pictures----the concrete should be open enough to clear the tub drain---is it?
Old 11-09-2011, 11:26 PM   #3
I will try to get a picture up, the concrete is opened up a little bit around the drain so I could dig down a little bit to lower and cut the elbow down, or get a shorter one it if that's what you are thinking...?
Old 11-10-2011, 05:40 AM   #4
DIY staff
I'd need to see what you have to work with there---there are a few 'fixes' for awkward tub drains--including solvent weld drain sets .
These have a heavy pvc drain and over flow --and use regular 1 1/2 inch PVC pipe and fittings--allowing you to shift the hook up location .
Old 11-10-2011, 04:16 PM   #5
Handyman
Rewards Points: 512
This is why God made Mr. Fernco??
canadaclub is offline   Reply With Quote
Old 11-10-2011, 08:05 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 904
I have read the OP's post several times but I can't picture it. Where is the 90 located? Are you referring to the drain shoe?
Old 11-10-2011, 10:03 PM   #7
These are the pictures, the elbow that I was talking about is at the bottom under the T-connector. More like a 45 degree than a 90. So if I can lower that in any way than I would be able to use the tub I have instead of having to take back this tub and get a new one.
Old 11-11-2011, 06:32 AM   #8
DIY staff
Can you dig out the part under the threaded trap adapter?
What is that piping made of?
Old 11-11-2011, 11:25 PM   #9
The pipe is ABS pipe. Could probably dig down, I think it's mostly broken pieces of concrete and earth surrounding the pipe.
The Following User Says Thank You to spike1985 For This Useful Post:
oh'mike (11-12-2011)
Old 11-12-2011, 06:05 AM   #10
DIY staff
I think the effort will pay off----that zig zag piping you are thinking of doing will be a maintenance problem ---Impossible to rod if hair ever clogs up the pipe.
Basement Reno ahrens General DIY Discussions 3 06-12-2011 02:17 PM
Small Tips for Basement Reno hellothere123 HVAC 2 02-17-2011 04:52 AM
Housewrap for basement reno mashedthumbs Building & Construction 3 01-23-2010 12:31 AM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 12:21 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
