Old 02-25-2007, 11:55 PM   #1
Tub re-install problem
Situation: Under the tub in the sump, there is a male compression adapter, though only the threads are actually above the concrete. The adapter is cross threaded. Now what?
Tscarborough is offline   Reply With Quote
Old 02-26-2007, 10:22 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Anyway you miight beable to trace the threads with a knife, just enough to allow the nut to thread it's self back on?
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
cutting shingles to install gutters Chicago Bill General Discussion 2 02-27-2009 06:42 AM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 10:05 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
