Tub Overflow Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2010, 11:04 AM   #1
Rewards Points: 358
Tub overflow drain?
I needed to replace my tub water stopper, so I found a kit which included a matching overflow drain. So I removed my old overflow drain and I noticed there is no seal between the tub. Should there be some sort of seal between the tub and the overflow drain itself? it seems as the water would just flow to the underside of the tub and rot out the wood. (thinking this I went under the house to check it out and all looks solid)
cbzdel is offline   Reply With Quote
Old 05-11-2010, 12:03 PM   #2
Yes, there should be a gasket installed on the outside of the tub that is held in place by the inside overflow cover. I use a small amount of flux to hold the gasket in place while installing the cover to prevent it from falling down.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
The Following User Says Thank You to majakdragon For This Useful Post:
cbzdel (05-11-2010)
bathtub overflow drain not lining up plumbernewbie Plumbing 6 09-18-2010 05:34 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 10:24 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Condensate Overflow Drain Pan sspatriots HVAC 10 03-30-2009 01:19 PM
Help with Overflow Drain Kit for Bathtub ... njchan Plumbing 1 01-08-2008 11:32 PM
