Tub Overflow Cap - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-13-2010, 06:49 PM   #1
Tub overflow cap
We are replacing our tub overflow cap but there are no screws visible for us to remove it. How do we go about removing one if it has no screws on it?
DenisePenney is offline   Reply With Quote
Old 09-13-2010, 08:17 PM   #2
does it move clockwise or counterclockwise? Some are attached under that cap, and the cap is just threaded on
the_man is offline   Reply With Quote
Old 09-15-2010, 06:09 PM   #3
Turn
It turns clockwise about a quarter of a turn.
Old 09-15-2010, 06:34 PM   #4
Rewards Points: 262
Were you able to remove the cover. If not the only other alternative would be to access it from behind the tub, hopefully through an access panel.
Jim F is offline   Reply With Quote
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 09:29 PM
cleaning the overflow of a sink Red Squirrel Plumbing 2 08-06-2010 08:51 AM
Tub overflow drain? cbzdel Plumbing 1 05-11-2010 01:03 PM
Overflow question davedfa Plumbing 1 06-02-2009 09:56 PM
Overflow pan in attic danstar25 HVAC 13 09-16-2008 04:42 PM
