Old 03-03-2006, 10:05 PM   #1
Outbacker's Avatar
Default Tub leaking past shower curtain
I am hoping that someone here can offer a solution to a small problem that we have with our tub. It is a large soaker tub with a curved side to it where you step in. The curtain hangs and at the front of the tub we need to place a bottle of whatever on the vertical part of the curtain and jam this up against the tub wall to prevent water from the shower from leaking past the gap that is created when the curtain hangs naturally. Here is a picture of what I mean:
Top picture is with a bottle in place, and the bottom picture shows the gap without something holding the curtain against the shower wall.
Any suggestions for this problem is looks nicer then this would be appreciated. Thank you.
Bob
Victoria, BC
Outbacker is offline   Reply With Quote
Old 03-04-2006, 01:15 AM   #2
I have a shower curtain with suction cups. Usually I leave them attached and get in the other side of the shower...
Bob
bob the builder is offline   Reply With Quote
Old 03-04-2006, 02:18 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Simply hang a lighter weight plastic shower curtain liner inside the outer curtain and stick it against the wet wall of the shower on both ends. They're available anywhere shower curtains and accessories are sold.
Been doing that for years, and my shower never leaks.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-06-2009, 12:51 PM   #4
Default I have the solution to leaking shower curtains
I have a new product on the market that prevents shower curtains leaking outside of the bath when taking a shower.
At last a solution for leaking shower curtains!
Splahblade is offline   Reply With Quote
Old 11-06-2009, 02:14 PM   #5
you can get plastic adhesive 'baffles' that stick to the tub and wall to keep the water inside the tub for pretty cheap. I don't know what they're called exactly. It may do the trick. They're about 4 to 5" high and long, and stick right in the corner where the wall meets the top edge of the tub. This will work for any water running down the wall that would normally spill over the edge of the tub, but won't stop the spray that may come out of the gap between the wall and curtain.
My mom has the same problem and uses a rolled up towel to collect water at the outside base of the tub.
DIYguy2000 is offline   Reply With Quote
Old 11-07-2009, 12:21 AM   #6
I am just curious. Is it possible to install a glass door?
Does the curve of the bathtub prevent to install a straight door?
Or, Is there such a thing as a rod which will provide the same curve
at the corner where the tub and the wall meet?
I have seen on ASK THIS OLD HOUSE where the plumber installed
a curved rod all around a stand-alone cast-iron bathtub.
Does anyone agree with me?
gabriel246 is offline   Reply With Quote
Old 11-07-2009, 09:18 AM   #7
Default Splasblade
Take a look at the web site www.splashblade.com
More On This Topic
This is Kevin with Expert Village we are going to one day bathroom remodel. Now if you notice Kevin has to stick the strip completely with his left hand so he can keep pressing firmly where no bubbles appear under the surface. Once you have it going and... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk here for a second about baffles. These are what we call baffles right here... Read More »
Now we're going to be applying some Velcro to our puppet theater. We're going to need two pieces of the fuzzy side of the Velcro. This is Velcro with adhesive, and you want it to be two pieces as long as the window section. You want two pieces about a... Read More »
Keep all areas of your home neat and tidy including your curtains. Although you don't need to clean them weekly, they do need cleaning. You want to remove any dirt and dust from the curtains without ruining the fabric. Follow these directions to wash... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we'll be turning off the water. Now some tubs have an access panel or you can actually reach into the wall and they'll be a shut off valve located in the wall that will just shut off the water... Read More »
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 04:58 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 02:01 PM
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 11:05 AM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 12:33 PM
Leaking Shower Fucets kishpj01 Plumbing 1 06-05-2005 11:38 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
