Old 05-31-2009, 08:09 PM   #1
Default Tub leaking from drain
Hello,
I found a leak in my basement today. Turns out it is leaking from a pipe that is connected to my tub drain. Not sure if it is called a waste elbow or not. My question is, can I just replace this piece or do I have to purchase a new drain assembly?
sweetwaters is offline   Reply With Quote
Old 05-31-2009, 09:50 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
A "shoe" has a rubber seal up under the tub. You might just be able to replace that and/or the metal piece with it. You shouldn't have to replace the whole thing.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
More On This Topic
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
Hi! I am Angela on behalf of expertvillage.com, and right now I am going to be taking about posture and the pains that can be induced from poor ergonomics and posture. Ergonomics is how your back is positioned and how your chair is structured. If it is... Read More »
Leaking bathroom drain. Concrete subfloor... Help crashtah Plumbing 2 05-27-2009 06:42 PM
Leaking drain valve in hot water heater rhelfand Plumbing 4 05-18-2009 10:51 AM
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 09:42 AM
Bath tub leaking through Drain nitu_752002 Plumbing 5 03-31-2008 11:22 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 05:37 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
