Old 02-03-2012, 07:10 PM   #1
MarginallyQualified
Tub install & support
I'm relocating the tub.
Currently it is supported off a wall in line with the floor joists.
(Joists are doubled up and have a lally column too)
The new location will be perpendicular to the floor joists.
(With a total of six joists sharing that load.)
Q: Is any additional floor framing/support needed?
Old 02-03-2012, 08:08 PM   #2
Super Moderator
A properly framed floor can support an iron tub without any extra supports---
Old 02-04-2012, 05:59 PM   #3
as mike said...but what type of tub are we talking about?
Old 02-04-2012, 07:19 PM   #4
MarginallyQualified
60x32 Deep Well
Probably an Americast Steel/Porcelain "Cambridge"
Old 02-04-2012, 07:22 PM   #5
Originally Posted by TarheelTerp View Post
60x32 Deep Well
should not be a problem all within standards of normal framing....
How to support counter top artlover13060 Carpentry 7 08-05-2011 06:50 AM
Main structural support beam HELP!!! Daniel048225 Building & Construction 34 02-17-2011 12:35 AM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-29-2011 12:10 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 10:02 AM
