-   -   Tub-hot! Shower-not! (http://www.diychatroom.com/f7/tub-hot-shower-not-167726/)
Mdwdirect 12-29-2012 07:28 PM
The water temp from the tub spigot accurately corresponds to the temp control on the handle. Turn it to hot, water comes out hot. But when I pull the spigot stopper up to engage the shower the water never comes out of the showerhead as warm as it did the tub spigot. Not even close...it's barely warm enough to shower when it's cold in the house.
It's a new Kohler fixture. I've opened it and adjusted the stop screw to allow hotter temps, water heater is fine, sink is in line with the tub and it's fine.
What is going on with the shower temp?
epson 12-29-2012 07:45 PM
Does the spigot stopper turn? If it does turn it to the left to get hot water, a picture of your unit would be nice.
Mdwdirect 12-29-2012 07:58 PM
Here is a link to the exact same tub fixture set:
http://m.us.kohler.com/mt/www.us.koh...log/428492.htm
I suspect the problem is the Rite Temp valve won't allow the right temp. How ironic if it's true.
Stopper does not turn.
epson 12-29-2012 08:07 PM
K if you take the cover plate off you will find a adjustment screw behind it.
Mdwdirect 12-29-2012 08:16 PM
As I said in my original post I've already adjusted the screw to allow hotter water through the valve. It did nothing to change the shower temp. No affect at all.
joeplumber85 12-30-2012 10:27 PM
The only thing I can think of that could be causing this issue is if perhaps the spring on the hot side of the PBU was busted and the pressure build up in the valve when the tub spout was blocked was enough to restrict flow to the incoming hot water.
Mdwdirect 12-30-2012 10:38 PM
PBU? What is that?
joeplumber85 12-30-2012 10:47 PM
http://www.us.kohler.com/us/catalog/...tNumber=500520
Pressure Balancing Unit
It's a protective device inside the Rite-Temp valve which protects the user from a sudden drop in presssure. If, for example, you were having a shower and I shut off your hot water, instead of getting a burst of only cold water, the PBU would let NO water through.
I've had to take them apart a few times when sand, dirt and other small particles get stuck in the small openings.
Mdwdirect 12-30-2012 11:01 PM
That is a likely culprit. I have another recent post about a contractor hooking his compressor up to my house bib to pressure test the new water lines he installed. Debris could have become lodged as a result.
I'm pretty handy mechanically but I've never done any torching. Can a noob get this part out and back in?
joeplumber85 12-30-2012 11:16 PM
Could or Should?
Could you? Of course.
Should you? Probably not.
If you do decide to attempt this, make sure your shower valves integral shut offs are OFF, and I'd also make sure your primary water is off as well just in case the integrals don't completely shut off due to some rocks or sand, and you end up with water pouring out and down inside your wall.
If you take a look at the explosion diagram of the valve on kohlers website, or if you still have it with you, it should be pretty straight forward getting it apart. Just be careful not to lose any of the o-rings when you are pulling the pieces out.
Alan 12-31-2012 09:36 AM
:huh: :laughing::laughing:
Javiles 12-31-2012 10:04 AM
remove the Shower head and check the water coming out of the open shower arm see what happens.
Mdwdirect 01-24-2013 08:33 PM
The shower head has nothing to do with the water temperature. And even though I think this is perfectly obvious I swapped heads to be sure and I was right, no change at all.
Mdwdirect 01-24-2013 08:39 PM
Originally Posted by joeplumber85 (Post 1082954)
Could or Should?
I see no exploded diagram at the link you sent in the previous message. And that part has been replaced with another one. It also has no exploded diagram.
I've searched the Kohler website--it's terribly designed from a homeowner's perspective--and found nothing helpful at all. Can you link a diagram or youtube video of the process from start to finish?
A lot to ask, I know. I'm not expecting anything but it is worth asking just in case. :-)
