Old 10-03-2014, 09:45 PM   #1
Rewards Points: 824
Exclamation
tub has defect what to do
guys it gets worse and worse. i am about ready to toss in the towel here.
so i went to dry fit the w/o kit, and the angle of the tub makes it so that the overflow pipe is pushed off to an angle that it wont fit in straight into the p trap. so what do i do now???
i literally just spent over 2 hrs trying to figure it out
federer is offline   Reply With Quote
Old 10-03-2014, 10:03 PM   #2
Rewards Points: 540
You need to move the trap away from the tub with a longer pipe connecting the drain shoe to the overflow. Can you post some pics?
Dan
djlandkpl is online now   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
federer (10-03-2014)
Old 10-03-2014, 10:15 PM   #3
DIY staff
Rewards Points: 2,384
Over flow shoe is installed first--it goes straight down --and eventually hooks into the drain---drain shoe joins the over flow with a T--
the over flow has a rubber gasket--that is tapered---spin the rubber gasket until it allows the pipe to go straight down.
oh'mike is online now   Reply With Quote
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
djlandkpl (10-04-2014), federer (10-03-2014)
Old 10-03-2014, 10:27 PM   #4
Rewards Points: 824
damnit. so i am supposed to install the overflow first????
Old 10-03-2014, 10:28 PM   #5
Rewards Points: 824
if i do overflow first though, the trap will be at an off angle and i wont be able to push the trap into the connecting t
Old 10-03-2014, 10:29 PM   #6
Rewards Points: 824
here is a pic
Old 10-03-2014, 10:44 PM   #7
DIY staff
the pipe between the drain shoe and the T-is way to short---
are you trying to reuse the old P-trap? is the T- set that short so it will hit the existing P-trap?
Old 10-03-2014, 10:51 PM   #8
Rewards Points: 824
oh my god....it wasnt that short i just cut it down twice because i was trying to get it to line up with the rest of the kit
the old tee slides right into the p trap
Old 10-03-2014, 10:59 PM   #9
DIY staff
Let's start at the beginning---
Is the tub in place or still sitting in the box?
Old 10-03-2014, 11:14 PM   #10
Rewards Points: 824
its standing sideways next to the opening....
floor is open right now. i was going to dry fit the kit to teh tub first, then install it for real, and drop it all in together to the floor. good?
Old 10-03-2014, 11:17 PM   #11
Rewards Points: 824
here is what it looks like right now. the tub is right next to the opening. i also need to cut a 1/2in along the tile border to have the tub fit. i think i am just going to tear up the row of tile instead of cutting it (because i want to keep my fingers mike)
Old 10-03-2014, 11:18 PM   #12
Rewards Points: 824
bascially the plan is:
1. install w/o kit onto tub
2. nail down new plywood. put felt paper on top. then put mortar cement like you told me.
3. place tub in cement and level
4. let it cure
5. connect w/o to p-trap
6. thank mike again
Old 10-03-2014, 11:28 PM   #13
DIY staff
#1--measure from the studs (at the wet end) to the center of the floor drain--
#2--measure from the back wall studs to the floor drain center.
Next--attach the overflow horn and the drain shoe to the tub--
How far in does the T need to be (from the drain shoe) in order for the t to meet the P-trap?
Old 10-03-2014, 11:49 PM   #14
Rewards Points: 824
#1 the stud on drain side to drain is about 9/10 inches. i forget wrote it down somewhere too many numbers floating in my head
#2i dont know this distance....
what do you mean 'how far in" do you mean how far out?
Old 10-03-2014, 11:51 PM   #15
Rewards Points: 824
oh you mean how far in from the stud wall? the way its set up now the p trap is right against the stud edge i would like to keep it that way
manufacturing defect on buth tub rajibchandra Plumbing 3 04-26-2012 09:07 PM
Just ripped out a newly installed floor because of a defect in tiles and need advice! mcu Flooring 21 03-01-2012 12:02 PM
Quick step Eligna Defect? GCap Flooring 5 06-26-2011 03:52 PM
Sold condo just realized it had a code violation Dave0009 Electrical 41 12-06-2009 07:45 PM
Found Roof Rot due to installation errors after labor warranty expired OneTripper Roofing/Siding 7 06-24-2009 02:59 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
