Tub Gasket ID Too Small, Can I Cut It? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2012, 06:24 PM   #1
Rewards Points: 89
tub gasket ID too small, can I cut it?
The gasket under the tub, between the tub and the drain. i would like to replace it since i am there and it is old. but it is a difficult size and one at the store is close at ID a bit off OD but not sure if OD is that important. If I trim the hole a bit do you think it will be a problem? Certainly I will not cut smooth and perfectly round. I think I would keep it a just a wee bit small but big enough the drain will fit in.
If the drain ends below the gasket I think it should be ok, If it is still above the gasket then not sure. Anyone know? or got an idea?
It is a 2 inch drain, I have already been through a lot just finding a replacement drain and should have got a gasket then if I could but did not. yes it is a 2 inch tub drain.
papason is offline   Reply With Quote
Old 03-15-2012, 08:18 PM   #2
DIY staff
Rewards Points: 7,174
The gasket works under compression--so an imperfect hole should not matter---I say go for it.
gasket material for venter bolower assmbly paulat120 HVAC 4 01-04-2012 07:07 PM
New shower drain installed, but gasket not sealing dryvlyne Plumbing 5 10-23-2011 09:29 PM
Small dip in concrete floor. kath81 Flooring 3 11-12-2010 04:32 PM
heating small bathroom floor - maybe rtoni Flooring 0 09-22-2010 03:11 PM
Curved Small Stage jalaux Carpentry 1 07-09-2006 09:57 PM
