Tub Fixtures Sticking Out From The Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2010, 08:05 AM   #1
Tub fixtures sticking out from the wall
This isn't a 100% DIY question since the work was performed by contractors but being the curious type I'd like to know what I'm dealing with prior to trying to get them to fix it under a warranty. And if I ever run into it again it would be nice to know so I can try to fix it myself.
Anyhow - roommate was cleaning the tub last night when a tile popped loose under the cover for the mixing valve for the tub. This morning while I was in the tile popped all the way off and the whole assembly came forward 1/2" or so (see pictures.) Something obviously wasn't done correctly (or there are bigger issues?) and I don't know enough about the stuff to really know what the underlying problems are.
cellophane is offline   Reply With Quote
Old 04-09-2010, 10:07 AM   #2
47_47's Avatar
Rewards Points: 76
It looks like they didn't secure the mixing valve. Do you have access from the other side?
47_47 is online now   Reply With Quote
Old 04-09-2010, 10:27 AM   #3
the otherside is a stairwell with a sloped ceiling. in theory, yes, there is access from the other side. in reality i'm not sure how it all lines up or how much drywall / plaster repair there would be (original house is plaster & wood lathe.)
Old 04-09-2010, 10:31 AM   #4
make them fix it. go thru tile side of sower and if need be have them retile that fixture wall
The older I get the better I was
Old 04-09-2010, 01:37 PM   #5
thanks for the info & advice. is there a way to protect or at least try to protect the inside of the wall until everything is fixed? this is the only shower in the house and the thought of not showering doesn't really appeal to me.
Old 04-09-2010, 09:53 PM   #6
remodeling pro
I agree with 47 47, they obviously did not secure the mixing valve for starters. Secondly, you may as well go through the tile, as it seem there is a problem with it also. It should not have popped off the wall that easily. Makes me suspect tha they used mastic to glue tile onto sheetrock. It should be glued to a cementous backer board with thin set. Sheetrock is a gauranteed failure in a wet area; and don't let them win the argument that they used "waterproof green board".
troubleseeker is offline   Reply With Quote
Old 04-11-2010, 11:49 AM   #7
The backer is cement board and i'm pretty sure it was thinset - but I'll ask. The whole bathroom was gutted after purchase so the board is new. From what I could tell the valve was pushing on the tile itself which is why it popped. Someone somewhere didn't do their job correctly, probably a few people...
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
