Tub Filler - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-17-2011, 09:09 AM   #1
Tub filler
Hi,
I screwed to much the little back screw on the tub filler and the pipe broke. See pic. I ordered the damage part from Moen but I don't know what to use or where to buy something to take out this part.
Can you help me naming this tool to take out this bolt inside the pipe?
EHouse is offline   Reply With Quote
Old 07-17-2011, 03:44 PM   #2
Try an "easy out". Auto parts stores carry them usually, but sears or any of the big box stores also carry them. They look a little like a drill bit, but they are tapered (they get narrower towards the tip) and the flutes are left handed. You put it in and as you turn it counterclockwise it digs in and you should be able to back out the broken nipple. You will need to have an idea of what size pipe you are trying to back out because they come in various sizes. Good luck.
Izzy
izzyk is offline   Reply With Quote
Old 07-24-2011, 08:34 AM   #3
Izzy
Thanks Izzy. I will try it.
Old 08-06-2011, 05:26 PM   #4
The Damage part came with the special too needed to take out the nut. Loved the service of this brand.
Old 08-06-2011, 05:27 PM   #5
Sorry, I meant the replacement part came with the tool needed.
Tack filler strip to plastic threshold? Richo Carpentry 1 07-09-2011 03:31 PM
Please help -- filler piece again wood plank wall mudworm Carpentry 3 06-28-2011 06:13 PM
Filler recommendations for wood floor phavel Flooring 1 04-10-2011 09:47 PM
Filler needed on oak or not? adjason Flooring 8 06-23-2009 03:57 AM
do not use concrete filler to fill stones... KUIPORNG Landscaping & Lawn Care 4 08-29-2008 05:16 PM
