-   -   Tub faucet runs when shower is on. (http://www.diychatroom.com/f7/tub-faucet-runs-when-shower-32871/)
Joeurda 11-30-2008 11:00 AM
I've got a problem with my tub faucet.
When I pull up the valve on the tub faucet to send the water to the shower head there is still a considerable amount of water that comes out of the tub faucet.
Is there something that can be fixed in the faucet or do I have to replace the whole assembly?
Thanks in advance.
Joe
Mike Swearingen 11-30-2008 12:08 PM
You have to replace the tub-spout-with-diverter.
It will either screw on, or slide on and be held with a set-screw. If there is a slot in the bottom of the spout near the wall, look for a set-screw with an Allen wrench head to eb loosened so that you can remove the old spout.
If there is no slot, unscrew the spout counter-clockwise to remove it.
Wrap 2-3 flat wraps of teflon tape wrapped clockwise only on the threaded end of the pipe sticking out of the wall before installing the new one.
You should be able to tighten it on by hand or a strap wrench to keep from marring the spout finish.
Good Luck!
Mike
