Tub Faucet Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-26-2009, 11:16 PM   #1
Tub Faucet Removal
I am having trouble removing my tub faucet. There is no screw underneath the faucet, therefore I am assuming it is a twist off model. I've only tried twisting the faucet by hand, as I am afraid I could damage the plumbing behind my wall. My house was built in 1967, so this could be a very old model faucet. Any ideas as to how I can safely remove this faucet?
novice_ is offline   Reply With Quote
Old 07-27-2009, 01:05 AM   #2
Registered User
Termite's Avatar
Nearly all of them twist off counterclockwise. With 40 year old plumbing you never know what'll happen. If it needs to come off you don't have much choice but to start twisting and hope for the best. Most of the time they come off without too much fuss. Worst case, you break a pipe that was in bad shape and needed replacing anyway.
Old 07-27-2009, 11:54 AM   #3
LeviDIY's Avatar
Rewards Points: 252
Try inserting a flat head screwdriver into the faucet opening for a bit of torque?
LeviDIY is offline   Reply With Quote
Old 07-27-2009, 01:22 PM   #4
I've tried the screw driver method, but no luck. That thing is really stuck on there. Being that there is no set screw, the thing has to be a twist off type, right?
Old 07-27-2009, 02:31 PM   #5
Registered User
Termite's Avatar
I doubt there was any other type 40 years ago. Big channel locks or a big pipe wrench are the ticket. You aren't going to get it by hand.
Old 07-27-2009, 10:04 PM   #6
I got home with my brand new pipe wrench and attempted to twist the faucet off, and the pipe came with it! It was threaded into the faucet, but it broke off right at the wall. Looks like I'll be calling a plumber instead of doing a DIY project.
Old 07-28-2009, 01:00 AM   #7
Registered User
Termite's Avatar
Sorry to hear that. Rest assured that the same thing would've happened to a plumber if they'd been the one to try to unscrew it. Old plumbing sometimes doesn't play fair.
Harden faucet stem removal jrm Plumbing 42 03-20-2016 10:42 AM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 02:25 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
Roman Tub Faucet Removal LennyM Plumbing 3 08-02-2008 02:22 PM
faucet stem removal rickyr Plumbing 1 11-13-2007 04:21 PM
