Old 10-11-2012, 09:33 PM   #1
Tub faucet leaks
Hello, this is my first post, probably not my last one.
Here goes....
My tub faucet is leaking, so I put in a new valve.
older model sterling. New seals, etc.
Turn the water back on ...... still leaks.... hot water side....
After a couple days of asking I end up replacing the PRV (it was building to as much as 90 lbs)
As of right now the tub faucet still leaks.....
What did I do wrong Klik and Klak?
In the few minutes I've been here I may have discovered my problem..... what do you think?
"quote" from a different thread
Sounds like the "faucet" that you're referring to is the tub spout, probably with the pull-up converter knob at the end to turn on the shower.
There are two types of tub spouts, those that are threaded and screw onto a pipe fitting coming from the wall, or those that slip onto a straight piece of pipe coming out of the wall. You apparently have the latter.
There is an o-ring that seals the spout on the pipe to prevent it from leaking like that. The screw hole is for the set screw that holds the spout in place.
The easiest thing to do is to just replace the old tub spout with the same type. They aren't expensive and they're very easy to install...all you need is an Allen wrench to fit that set screw.
Good Luck!
Mike
Thee is offline   Reply With Quote
Bidet faucet leaks at the "chimney" noquacks Plumbing 2 06-19-2012 11:20 PM
Outside faucet leaks Bgreen Plumbing 1 07-27-2011 03:29 PM
Bathtub faucet leaks from screw hole under faucet. Debmmill Plumbing 3 02-13-2011 07:43 AM
My shower head leaks when tub faucet is running? Walter Sobchak Plumbing 4 05-24-2010 09:13 AM
Frozen outside faucet leaks -> Hose left attached k6trouble Plumbing 11 04-22-2010 06:36 PM
