Tub Faucet Leak- Cant Remember The Rule - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-05-2012, 09:38 AM   #1
Rewards Points: 1,062
Tub faucet leak- cant remember the rule
People,
There is a rule regarding which of the 2 types of leaks one should be aware of- My leak occurs ONLY when faucet is on. It leaks from the cold water knob. When faucet is off, no leak.
I remember ths was key in determining if a leak is caused from the knob washer, or the main faucet stem seat/washer.
Thanks!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 09-05-2012, 09:46 AM   #2
Rewards Points: 13,694
I've never heard of a "rule" for figuring it out.
In your case it's the stem seal.
If one's leaking may as well fix both at the same time even if it's not leaking.
noquacks (09-05-2012)
Old 09-05-2012, 10:04 AM   #3
Good deal, Joe. Should I start with unscrewing the faucet , then look inside at he innards for some type of washer/o ring?
Old 09-05-2012, 10:17 AM   #4
some have a hex nut under the handle you can try tightening a little or you might have to buy some packing material, others have o-rings around the stem on the inside and you would have to remove the stem to replace it.
Old 09-05-2012, 11:01 AM   #5
Thanks, Danny. Will do it.
Hot water faucet leak in shower flaterrie Plumbing 4 08-30-2012 06:38 PM
Ice in Cover over Exterior Faucet SPetty General DIY Discussions 13 01-11-2010 03:32 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 01:26 PM
Bathtub faucet leak... bozonoz Plumbing 4 09-08-2009 08:02 AM
delta tub faucet leak lnba Plumbing 4 08-25-2009 02:27 AM
