Tub Faucet Install Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2008, 01:05 PM   #1
Rewards Points: 1,062
Question
tub faucet install question
1. what is the standard height of the diverter spout relative to the tub ?
2. what is the standard height of the face plate relative to the tub or how high above the diverter spout ?
3. the face plate backend piece, whatever you call it, the piece that it all hooks into, are they typically of a standard depth across manufacturers so that also there is a recommended depth for setting it into the framing ? e.g. how deep to set the horizontal 2x4 blocking piece on which it rests ? i understand i can take two layers of cement board (2nd one to approximate the thickness of tiles+thinset) and set it on the studs to get an approximate position but was wondering if there is a standard, like 2 inches or so ?
thanks,
- a -
Old 06-24-2008, 02:53 PM   #2
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
You could ask 100 plumbers and get 100 different "standard" dimensions. Here's one trick to make yours look good.
Measure the distance from the floor level to the level of the overflow inside your tub. It doesn't have to be exact, just close. (On many tubs it is about 11"). Now measure up 11" from that for the spout and 11" higher for the face plate. This will put your face plate at 33" high and make everything look even. A good height for the shower head is 6" 10", but this is really up to you.
As for how deep inside the wall to rough the valve, that is entirely dependent on the individual valve and the thickness of wall covering planned. Most new valves will come with a rough-in plate, or plaster guard. The front face of the plaster guard should be flush with the FINISHED wall surface. These instructions are usually printed on the plastic plaster guard. If you don't have a plaster guard, go ahead and put the trim together on the valve and see how much play you will need and set the valve accordingly.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 06-24-2008, 03:25 PM   #3
thank you sir/madam !
Old 06-24-2008, 06:00 PM   #4
mstplumber's Avatar
Rewards Points: 150
You are welcome.
Mstplumber
Old 06-24-2008, 10:35 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
tub shower we go 32" to center of valve
from center of valve down to tub spout is usually about 6 inches.
Showerhead is roughed at 80" from rough floor, unless we have a tall shower then we go 82 or 83.
Journeyman Plumber
Old 06-25-2008, 08:34 AM   #6
mstplumber's Avatar
Rewards Points: 150
Just be careful that the trim you are using doesn't have so large of a faceplate or tub spout base that the face plate and spout interfere with each other. Some of the newer trim styles can have this problem, just check that first.
Mstplumber
Can I install a kitchen faucet on Utility sink/tub?? TDRohn Plumbing 4 09-17-2008 01:13 PM
light install question jscholl411 Electrical 5 11-30-2007 12:50 PM
Question about a kitchen faucet skwpt Plumbing 10 10-11-2007 07:54 PM
Pressure Balanced faucet question scp Plumbing 2 01-07-2007 06:15 PM
