Tub Emergency Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-10-2010, 08:52 PM   #1
Rewards Points: 1,088
There's an overfill drain in a tub that's located right below the faucet. Most know that it's purpose is to prevent the tub from overfilling.
Is it necessary to put a bead of caulk over the top portion of the drain, or is there a gasket inside that prevents water from leaking in when the water is running/during a shower?
handy man88 is offline   Reply With Quote
Old 06-11-2010, 06:51 AM   #2
There is a gasket behind, between the drain vent and the tub. It is held tight by the trip lever screws/plate. No need for caulk.
The Following User Says Thank You to Just Bill For This Useful Post:
handy man88 (06-11-2010)
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Water flowing into emergency drain MetalChris Plumbing 7 08-09-2008 05:17 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Air Handler Emergency Drain Pan Outlet handy man88 HVAC 1 10-26-2007 07:22 PM
