Old 05-21-2012, 09:03 PM   #16
Tub drain very, very slow. please help!
I would personally tape off the over flow with duct tape. Fill it 1/4 full and throw the old shop vac on the drain, should have enough pull to dislodge the clog. Works every time!! cheers
bugmenot is offline   Reply With Quote
Old 09-29-2012, 09:36 AM   #17
Originally Posted by nmiller311 View Post
The shopvac technique was thr best ever. I have had a slow drain for a couple weeks and nothing was working. Snakes, plunger, chemicals, nothing. Five minutes of setup and ten seconds of shopvac and the clog was sucked up to where I could see it and snag it with a snake. I will definitely be using that method in the future if it slows down again.
I agree! Did this for my bathtub and it was back to normal in no time!
actormikebiddle is offline   Reply With Quote
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 04:15 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
