Tub Drain With Straight Shoe - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-19-2012, 11:57 AM   #1
Tub Drain with Straight Shoe
I work at a hotel where some of the bath tub plumbing is directly below the tub drain. They used a shoe that is straight through to the drain with a tee for the overflow. I have found a Gerber all brass setup that is similar but not as long of stem so I would have to extend it. I am looking for a PVC straight shoe can anyone help me?
Thanks Jeff
zeppo4 is offline   Reply With Quote
Old 12-19-2012, 12:06 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 834
check watco's website
The Following User Says Thank You to TheEplumber For This Useful Post:
zeppo4 (12-19-2012)
Old 12-19-2012, 12:13 PM   #3
Watco has it thank you so much.
Jeff
The Following User Says Thank You to zeppo4 For This Useful Post:
TheEplumber (12-19-2012)
Very slow drain no drain blues Plumbing 16 04-03-2012 05:39 PM
Reusing existing drain frahms_4 Plumbing 19 12-30-2011 02:27 PM
New Drain and Overflow assembly not fitting properly to new tub - Help plz amodoko Plumbing 19 12-21-2011 02:28 AM
Central Air Secondary Drain Leaking - 3 questions walters_12 HVAC 7 05-11-2011 03:20 PM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
