Update on Tub Drain Removal Tool:
First of all, I was able to remove the drain, using a hammer and chisel. it took about 6 to 7 revolutions of the drain before I was able to remove it by hand. The revolutions were not easy and it was slow going to make it rotate with each hammer tap. I made a V-notch on the lip of the drain and cut about a little less then 1/16 inch into it. Then I use a marking pencil and place a mark just below the V on the porcelin part of the tub. I wanted to make sure that it would move. Using my chisel, I place it into one side of the V and tap counterclockwise. After a few taps, I could see it moving and with each tap, the V started to open up giving me a bigger bite to work with. I made two V's on opposite sides. It took about 45 minutes to an hour before I was able to remove it. It was seized up real well.
Now for the tub drain tool:
When a tub drain is seized up as bad as mine was, then this tool is useless. All it does is apply pressure to the sides of the drain. The instructions that came with it are not correct. It states to keep on turning the threaded center stem counterclockwise until the drain breaks free. This is impossible because the tighter you turn the stem in, the tighter the male drain threads are pressed against the female threads. Even after realizing this, I use a wrench to rotate the the whole tool in the hopes it would also rotate the drain and all it did was slide around the hole. It cost me $40.84 to find out that this tool is useless for seized tub drains. You can view this tool at:
www.plumbingsupply.com
Go to the alphabet index and click on T, then look for Tub drain removal tool. There are two tools. The one I am referring to has three shoes encircling a cone shaped stem that will expand the shoes as the center stem is turned counterclockwise.
Now this tool may work on drains that are less seized then mine but don't follow the instructions if it says to keep turning the center stem. This is wrong. Just turn it enough to give you a bite on sides of the drain. If it slips when you try to turn the whole tool like I think it will; then its probally time to get out the hammer and chisel.
Before I installed the new drain, I placed a few wraps of teflon tape around the threads in the hope that it will prevent seizing in case it needs to be removed at a later time. I used a bit of plumbers putty on the underside of the new drain for sealing.
And the rubber or vinyl washer that comes with the new drain, is installed on top of the fitting on the underside of the tub. It does not go between the tub surface and the new drain. The instructions on my new drain did not mention this.
