Tub Drain Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2014, 12:32 PM   #16
bryanp22's Avatar
Rewards Points: 298
Tub drain removal
It's our only shower so I cut it with a reciprocating saw. I need to try and get this finished today. Crazy part is the drum trap pipes are all corroded but now that I can see down the rest of the pipe it's practically new looking inside. The drain key I got from menards was also to small so I just cut the old flange out.
bryanp22 is offline   Reply With Quote
The Following User Says Thank You to bryanp22 For This Useful Post:
jmon (03-29-2014)
Old 03-29-2014, 02:44 PM   #17
DIY staff
Rewards Points: 7,174
Good luck--keep us posted----
Old 03-29-2014, 04:56 PM   #18
bryanp22's Avatar
Rewards Points: 298
Tub drain removal
All done no leaks. Most frustrating part was where the drain y met the p trap. I had to cut a piece of pipe to just meet the hubs because of the height of the drain pipe. I did notice the old drum trap pretty much had the same thing it was just slight deeper so the pipe out of the drain y was about 3/8 between the hubs.
The Following 3 Users Say Thank You to bryanp22 For This Useful Post:
jmon (03-29-2014), oh'mike (03-29-2014), TheEplumber (03-29-2014)
Old 03-29-2014, 05:10 PM   #19
Rewards Points: 320
Nice job bryan! Glad you got everything working the way you want now. Thanks for the update. Sometimes ya just got to get r done.
jmon is offline   Reply With Quote
Old 03-29-2014, 07:17 PM   #20
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
Nice job replacing the drum. Worked a property that had 543 of those pitas.
Still have about 10 caps somewhere in my truck.
Gregg M.
gmaint is offline   Reply With Quote
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Scupper drain installation advice needed miamicuse Roofing/Siding 9 02-11-2012 09:59 AM
Removal of Bathtub Drain joe3534 Plumbing 4 10-22-2009 08:41 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Mystery floor drain removal guzman@wwdb.org Plumbing 2 04-03-2008 03:29 PM
