Old 04-05-2012, 12:48 PM   #1
Tub drain primer (not laundry)
I'm having my basement slab jackhammered up and a new one poured, and they will be roughing in plumbing for a full bathroom (tub, toilet, sink), and a laundry drain.
I've been able to find lots of information on a primer for the floor drain primer, and will have them run a 1/2" line to the floor drain for that purpose.
However, I'm having a hard time finding information on a drain primer for the tub p-drain.
My expectation is that the contractor will give me a 12" x 12" box where the tub trap will reside.
Since the tub trap won't be poured permanently in place, should I run a 1/2" pvc line for it, then transition to a flexible plastic line?
Any advice would be appreciated, plus any sources for plastic p-traps with primer nipples.
Thanks,
toddmanqa
toddmanqa is offline   Reply With Quote
Old 04-05-2012, 03:19 PM   #2
call me E
TheEplumber's Avatar
Typically, tubs don't have primers installed, but if you don't use it often it may not be a bad idea.
I use "bap adapters" on floor drains- not sure if they come in 1.5" They're glue couplings with an 1/2" fitting tapped into the side. Install it above the p trap. To prime the trap, I'd run 1/2" pex from the lav to the tub- in the wall, not the floor.
If you use a slip joint waste and overflow, perhaps use a DW or condensate tailpiece instead of the bap adapter.
Primers can also be supplied from a toilet too. The trap is primed when the toilet is flushed
Old 04-05-2012, 11:13 PM   #3
Doing it myself
Alan's Avatar
Here's a variety of waste/overflow kit with a condensate adapter built into the overflow shoe
http://www.plumbsource.net/product/A...low-Plate.html
This way you can skip the bap adapter.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
TheEplumber (04-05-2012)
Tags
drain primer, floor drain, p-drain, primer, tub
New Drain and Overflow assembly not fitting properly to new tub - Help plz amodoko Plumbing 19 12-21-2011 03:28 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 05:31 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
