Tub Drain Overflow Installation Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-12-2013, 08:18 PM   #1
Tub drain overflow installation problem
Hi all,
I am trying to install the overflow mouth piece into my free standing tub and I discover that it does not fit. Please see the pictures to give me idea of how to solve this problem?
As you can see the opening from picture 1 and 2. In picture 3, I installed the overflow piece w/o the drain pipe and it is way inside to screw the pipe in.
Thank you for your help.
Tub drain overflow installation problem-20130312_194151.jpg   Tub drain overflow installation problem-20130312_194159.jpg   Tub drain overflow installation problem-20130312_200804.jpg   Tub drain overflow installation problem-20130312_200918.jpg
lti2000 is offline   Reply With Quote
Old 03-12-2013, 09:27 PM   #2
Rewards Points: 616
what is you location?
where did you get the tub?
what brand is the tub?
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-12-2013, 09:32 PM   #3
Rewards Points: 12,830
I've never once seen a recessed area like that for a tub spout.
Old 03-12-2013, 10:21 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 350
Ikea?
Old 03-12-2013, 10:33 PM   #5
I see that as a leak waiting to happen.
Old 03-12-2013, 11:39 PM   #6
I bought it from Signature Hardware. The drain pipe is also from them specifically for the tub!!! It look like I have to deal with them on this issue.
Do you know if there is an extention or adapter or replacement that extend out 1" more?
Old 03-12-2013, 11:59 PM   #7
Rewards Points: 616
good luck dealing with signature. in the past i have done work for a designer who loves their stuff and always likes to order it himself including all the hardware they say is needed. with out consulting me. so when it gets to the job and does not work i get to deal with them and have never had good luck and usually end up ordering other parts or making or modifying parts to finish project.
Old 03-13-2013, 12:10 AM   #8
what model tub and what model drain do you have?
Old 03-13-2013, 12:25 AM   #9
Tub: 357762
Drain: 329531
shower drain problem firsttime1 Plumbing 1 07-18-2011 05:57 AM
overflow drain in non overflow sink? forresth Plumbing 1 10-06-2010 07:09 AM
Help with Overflow Drain Kit for Bathtub ... njchan Plumbing 1 01-09-2008 12:32 AM
Problem with tub drain lineup dotwell Plumbing 2 10-21-2007 09:58 AM
Slot Drain Problem keredwh Building & Construction 5 07-25-2007 08:51 AM
